Wow, this is all a bit new! Anyway…
I’m looking for a way to create a membership area of a RW site. Are there any simple stacks out there?
Joe Workman has a stack called Locker which looks pretty simple.
Actually Locker is not for memberships. It would be PageSafe that is for something like that. But it ONLY locks down the page it is on, and there is not options for usernames and passwords. Just a simple password
Thanks - have been finding a bit more information out from the client (my husband!) and it seems that it would need to be a complete management system, allowing admin to block people who haven’t paid their subscription.
I think you could do this with Stack Apps but I find it far from easy. I think this is something which would be much easier in WordPress.
What about “SiteLok”? It can easily be integrated into RapidWeaver…: http://www.vibralogix.com/sitelokpw/
What about “WeaverFM” from Gregory Barchard (ChiliDogs)? It is a complete membership management system for groups and individuals.
Member Login from phpjabbers can also be integrated into Rapidweaver. ( http://www.phpjabbers.com/member-login/ )
That looks promising. I might have a use for that myself.
This looks ideal, many thanks RapidBase!
Would’ve liked to try WeaverFM -but it won’t install in RW6.3 -? ‘Not recognized’; even manually putting the.plugin file with others in library/…/RW… and relaunching RW didn’t matter. Not sure if Chillidog’s ‘active’ and/or weaverfm is supported. Any current users?
