Hello, I published my new web site and I noticed that on the Google search stacked names images appear also between name site. what’s happening? Thanks so much for your help!!
RV
Google is reading the alt tags on your images and you I’m guessing didn’t put anything in so its using the stacks image name.
I suspect that Google is doing this because there really isn’t and text content on the page for them to return. I would suggest that you add a page description (meta tag) and also add a paragraph of info to the page for SEO.
Hello Williams, thanks for the reply. I’ll try to fix this.
