Suppression boutons impossible
RapidWeaver Elements b27 (23161)
Après la fermeture d"Elements, à la réouverture, cela à généré 2 boutons qu’il m’est impossible de supprimer.
Bon dimanche les amis.
Can you share the project with us via Elements Cloud?
elementsapp://downloadDocument/7CboHtQF1UIH
Thanks, this certainly looks like a bug, we’ll look into it and get it fixed.
In the meantime, just unlink them from a Global and then you should be able to delete them!
I found the same thing with SVG in your menus. You can’t get rid of the SVG (and it didn’t like my Adobe-created SVGs anyway), and if you drag it out or start fiddling with the Global, you can get into a state where you can’t remove it. As you note, Unlink from Global is the workaround, at which point you can remove it.
SVG’s are code based, so sometimes you have to tweak the output to get them to work the way you want on the web (this isn’t unique to Elements).
Take a look at the SVG Component Docs, it contains some advice on how to get size and colour working.
Thanks for the report, we’ll get this fixed in the next beta or two!
