T-shirt size options RapidCart Pro
For the life of me… cannot sort how to create a list of shirt sizes for the same shirt design. I’m sure this has been discussed but I cannot find it.
One shirt-six sizes.
How do you do this?
jack
You should be able to do it with the ‘Options’ setting for each product (or the ‘Option Sets’ for multiple products).
https://tls.4gnd.com/rw/rapidcartpro/manual/#build-your-catalog/versions-and-options
Also, there is a free demo store to download that I believe has different sizes of one product as an option that you could use as a template.
Perfect… exactly what I needed!
I was making it too complicated. Thanks!
