Hello!
I use theme Flood on my site. Do I nee do update it?
Not sure what version I am using or where to find that info etc…
Thanks for help
A
Hello!
Thanks for help
A
Hi @Amurman,
I don’t know if @willwood themes have any auto-update function built-in. If not you can check on his website https://www.themeflood.com/ to see if there are any updates to the theme you are using. You can check the theme version you have installed via RapidWeaver’s Preferences panel like so:
You can also message @willwood directly and he can let you know.
Hope that helps.
All my themes have support for “sparkle” automatic updates built in. However the update checker in RapidWeaver has always been highly temperamental. I have never once been prompted to install a theme update from any developer, but some people do still get notifications without any difficulties. So I guess luck has to be on your side if you get notifications.
At any time, you can click RapidWeaver 8 or RapidWeaver Classic in your menu bar, then click Settings. Click the Addons button and click Themes. There you can see all the themes you have installed from each developer, with their version number showing.
You can compare the version number listed there to what gets shown on the website. The details for every theme gets shown in the right sidebar, together with the version number.
If automatic updates are not working for you in RapidWeaver and you need an update for a theme, please send me an email through the website. Attach something that verifies your purchase.
All my themes are compatible with RapidWeaver 8 and RapidWeaver Classic.
Thanks so much for this.
I am on v.3.5.
Are these sufficient to prove that I have purchased this theme…? I’m sorry I don’t know where to find more clear proof.
My website is Namaskaryoga.com if seeing the site would better confirm the use of your Flood theme : )
Many thanks,
Alexandra
