My client has reported that she cannot update anything on her site. This started last Sunday.
Looking at the cms-log file, I can see a slew of these messages:
Wed, 09 Jan 2019 07:50:51 -0600 Passport check failed. You will need to register a passport to use TotalCMS further.
Wed, 09 Jan 2019 07:57:38 -0600 Domain trial period expired
Wed, 09 Jan 2019 07:57:38 -0600 Passport check failed. You will need to register a passport to use TotalCMS further.
Wed, 09 Jan 2019 08:09:19 -0600 Domain trial period expired
Wed, 09 Jan 2019 08:09:19 -0600 Passport check failed. You will need to register a passport to use TotalCMS further.
There are no messages in RW to show that a license code is required.
I could use some help to fix this.
So. far, I have cleared cache and restarted browsers.
Scott, I did that when I first started to use TCMS.
1.Should the working setting of the Admin Core Stack be on or off (dark or light)?
2.Do I need to make whatever setting for every instance of this stack.
