TotalCMS Trial : I have entered several categories and tags.
I edit them in Admin post, and save, but they don´t change
Are you saying they don’t change on the actual blog post, or they don’t change in the tag/category list?
The Tags and cats list Is auto generated as you type them in each post, the only way to remove or change one is to go to each post that contains the offending tag/cat and edit it there.
Yes, but when I want to delete one of 3 categories from a post? The change is not visible after saving
I will stop this TotalCMS test. It´s not working,
I need minimum to be able to edit the categories and tags…to add and to delete them, and it´s working either.
