Trying to string html components together
As I wrote most of these for practice rather than thinking ahead, I learnt quite a lot now
I tried putting my 3d spinning cube in the animation border component, one is percent the other pixels, need to change them both
First time I have tried grids so not finished that part
So put sinning cube with Elements logo inside at bottom
there are box circle triangle and multi clip path components as well
ok that didn’t work
All of my components are removed from my projects even each save
I think this is because you are copying components between projects, this does not work right now… should be fixed in the next few betas. Sorry!
