Im using the twitter code they supply but it shows a long line of tweets and really i only want one or two showing , can this be changed ?
I have Twitter Fetcher 1.5 but is not working and cant see it available anymore to try to update.
Doo box tweets but that doesnt work any more either !
If you go to your twitter account > Settings (click the small image in the top right corner) > Choose Widgets in the right vertical menu > Choose your widget (code) or create a new > Adjust the height > Copy and paste the code (to RW or Stacks).
