UIKit settings for fonts, colors, size in Rapidcart Pro
@rob What is the setting named in UIKit for these font/size/color options (see circled text in screenshots) in Rapidcart Pro? I have been fiddling like crazy but so many options I can’t figure out what they are related to in RCP.
On another note, how would I get the product in the cart to be closer to the options? There is a lot of empty extra space between them and it also makes it too wide for phones to see the product options.
thanks
This one is in the grid:
This one is in the cart options:
Product grid:
.rc-catalog-product-details h3.uk-panel-title {
    /* your style here */
Product options title:
div[id^=rc-product-options-modal] .uk-modal-header h3 {
Product options label:
div[id^=rc-product-options-modal] .uk-form-label {
Cart options:
@media (min-width: 768px) {
    #rc-cart-overview-form tbody td:nth-child(2) {
        width: 25%;
@rob… is this supposed to be in addition to the UIKit settings I already have, or instead of? If I wanted to change more settings this way (and not use UIKit), is there a list of code for things like this? For example, I thought I changed the code in UIKit for the primary labels/buttons/links, but not sure.
thanks
CSS is a cascade stylesheet, rules at bottom override rules above.
You can add the code at bottom of Style window.
thanks. I will try that.
Hi! Say please, how to remove the Country field when ordering the product?
And, how to add Cart on navigation bar?
I would like to know (in the UIkit) where the font-size-control is for the “Short Description” in a page’s grid of product panels. Any ideas how to change that from its default? (Mine’s too large.)
Thanks!
-Aaron Welch
