Updated Rapidweaver from 7.something to 7.1.7 today and I can't use stacks
After a while, I opened Rapidweaver to start building new project and then there was update offered, so I clicked update. After update, I have 7.1.7 abd the problem is, I can’t use Stacks anymore. All my old projects report error missing plugin Stacks. I reinstalled Stacks and it just doesn’t help.
I will look into this further now, on my second mac in order to see if it works there.
I’m sure your version of Stacks is too old. It should be version 3.2.6 (beta 3 is the latest one). Download this one… http://yourhead.com/appcast/RW6/beta/Stacks3/Stacks_3.2.6b3_3896.zip …and install it. Then restart RapidWeaver and all should be fine.
If you are going to use the beta of Stacks, I would also suggest you join the Yourhead Slack channel
http://slack.yourhead.com/
as this is the place to report bugs and issues with any of Yourhead’s software. Slack is a free app too.
