I donât speak German, but if youâre suggesting full access for RapidWeaver?
This has no positive effects.
Hey guys,
If you see âThe document [name] could not be saved.â error, please, please send your project to support@realmacsoftware.com so we can get it fixed!
Please donât resort to giving RapidWeaver full access to your drive. Itâs treating the symptom and not the cause.
Cheers
Yes, deleted my post due to the statement of Realmac that this is not the solutionâŚ
Thanks man
Schickst Du Dein Projekt an mailto:support@realmacsoftware.com ?
Viele GrĂźĂe
Jan
Ist geschehen.
Habe ich, danke!
@Volker Can you let me know which plugin versions you have? You can find this information by clicking the Addons button in the toolbar and expanding the folders.
Thanks! Could you do the other side too, with the version numbers - thatâs the info I really need.
I know it can be hard to get all the plugins in the screenshot, thereâs loads of them! You can collapse down the Realmac ones, I just need to know the version of the plugins youâre using in this project.
I donât know if itâs a plugin or not, but Iâve not been able to replicate it so far.
Cheers!
It shouldnât be the plugins. I deleted all plugins, except stacks. Even then I canât save.
I also deleted all pages and added a new stacks page with the text-stack. The result remains the same.
Thanks guys.
@perherman What version of macOS are you using?
@Volker @perherman Weâve just released a new version of RapidWeaver, 8.1.2. I donât think this version will fix your saving problems but it may give me the information I need to do so.
Could you update RapidWeaver, open your project and attempt to save again.
After that, choose âCopy Support Logsâ from âHelpâ menu and email the log file to support@realmacsoftware.com with a subject of âFAO: Tomâ
Cheers
Thanks for the logs! Iâve been able to reproduce the problem now and Iâm working on a fix!
Hey guys, RapidWeaver 8.1.3 is now available and will hopefully solve this issue!
Thank you very much, Tom. The problem is now fixed.
