Hello.
I have a project file made by Rapid Weaver 7.
I bought Rapid Weaver 8 Software, and I want to open RW7 file.
But I can’t open this file on RW8…
Hello.
If you try and open a RW7 file with RW 8, it should trigger a dialogue box asking if you’d like to convert it to an RW8 project file.
When you say you can’t open it, what is happening?
Thanks, dear jabostick.
When I was asked if you’d like to convert it to an RW8 project file, click [Upgrade] button, this message:
New Rapidweaver Project Created
RapidWeaver uses a new document format - and a new .rw8 project file has been created alongside your old RapidWeaver document. You should open the ‘●●●●.rw8’ project file saved by RapidWeaver in future to prevent changes being lost.
But, any contents be seen…
