Move Projects from RW7 to RW8
Just upgraded from RW7 to RW8 I had some projects saved in 7 how do I move those to 8?
Just open them in RapidWeaver 8 by either dragging and dropping on the RW 8 icon or open RW 8 and then opening the file. RapidWeaver will convert the file and save it as a .rw8 file, which means it will keep the RapidWeaver 7 file too, just in case there is issues with RW 8.
Thanks.
