rw7 files don’t seem to appear when trying to open in rw8, anyone has an idea?
Try this… find your RW7 project file. Right click on it and “open with” RW8. It will leave the rw7 file as is and “convert” it to a RW8 project. See if that works for you.
tried that, but found the problem now, apparently rw8 was not installed in the program folder… copied it and solved now, thanks
Isn’t this the same as you posted on a new thread?
Yeah. I posted here and then created a new one. I’ll delete this in a sec
