Urgent: RW hanging on launch due to corrupted project
Hi, I am going nuts. I try to launch RW (7.2.2) and because the project I had opened last seems to be corrupted RW always hangs while trying to open this project. How can I launch RW without it trying to open the recent project file?
Could you try moving the last project into a different location? Then, when Rapidweaver tries to open it, it will not find the project and then may open correctly?
That was my first thought as well - didn’t work. Even renaming plus moving - RW was smart enough to find it…
Zip it and delete the unzipped one
Good idea - downloading the 7.3 beta worked as well. I was able to open 7.3 with no issues and after that also 7.2.2 again, no remaining problems. Weird thing. Thanks everybody!
