Using Rapid Weaver to create an Ebay Template?
Would it be possible to use RW to create a HTML template for selling on Ebay?
Thanks,
I don’t use eBay so not sure what the requirements are.
You might check Doobox’s new offering:
https://www.doobox.co.uk/apps/app_demos/mailshot.html
Joe Workman also sells a set of stacks for creating HTML emails. They work quite well if you have Stacks.
Blessings,
—Mark
