I have a problem about publishing after upgrade to Version 8.8.3 (20877). It is not work.
I checked everything on server side and there is no problem.
What exactly did you check?
Who are you hosting with?
What specific “problem” are you having?
Some screenshots of your publishing settings along with any error messages would be helpful.
You also might have a look here, and go through all the steps outlined.
https://help.realmacsoftware.com/kb/guide/en/how-to-fix-publishing-issues-Z9eDEW9hUH/Steps/233393
4. Delete and re-add your publishing credentials
Problem is solved.
