Wall stack - missing posts?
Figured out how to get the FB part of wall stack working… so was :smiley:
Client has now pointed out that the posts imported have vanished??
Anything over a week appears to not load from FB, but the number of days in the wall stack setting is set to 365??
Can anyone explain why please?
Great to hear @Jon
Thanks for the feedback Michael.
Yes I’m using 1.4.5, I‘II limit the posts to 10 and see how I get on.
Cheers Jon
Thats worked :grinning: - the last 10 posts are now loaded.
Can I up the limit to 15-20 or will that cause a problem, with you saying 10?
:thinking:
Cheers Jon
Yes you should be able to, please try it :slight_smile:
Although some of the services don’t allow it but you’ll see soon enough in RW preview
Thanks for your help Michael, 18 loaded and the page filled and the clients happy! :smile: great stack btw :+1:
@jonline, Im super confused about getting the wall stack to work. Were you able to get the youtube function to work, if so how? Thanks in advance for your help. :smiley:
I’ve just done this now @BigNealy and you can see this in the demo project with the Stack:
You’ll can use:
  • search term
    or
  • profile ID + list ID
You can see in the manual how to set this up and you can also use the Keys in the demo project :slight_smile:
If you are having anymore issues, please message me on these forums
Sorry Micheal, Only just seen this. I only needed the FB element for the client, so I never looked at setting the video side up. It looks like Michael F has sorted you out in the meantime. Cheers Jon :blush:
