The problem is that you need this tag to submit your feed url to itunes.
With RW it is only possible to check explicit , to use it in your feed.
But this means explicit yes and iTunes displays a parental advisory graphic on your podcast. If you are doing a podcast for children or a business you don’t want that. This problem is not new, but now it is time that Realmac fix the problem.
Can you do something like this?
Still no answer from the support!
So i edit the feed .xml by my self with Cyberduck and the Text editor from “yes” to “clean”
and now iTunes shows this
Clean lyrics!!!
The bad thing is, i must edit the blog .xml every time i publish a podcast.
PLEASE fix it!!!
