RapidWeaver Version: 7.03 (17833b)
System Version: 10.11.5
Hardware: iMac (21.5 Zoll, Mitte 2011), 2,5 GHz Intel Core i5, 16 GB 1333 MHz DDR3
Issue:
iTunes did not accept Podcast Feed
After changing my podcast Feed, iTunes don’t accept the feed, because of two mistakes?
I don t use the Explicit Tag!
With Feed Validator the feed is ok!
Feed: Silbersurfer's Kosmos - Der Podcast
Set the Podcast to explicit, then the feed url was accepted!? Changed it later to normal and it still works.
But now my podcast was deleted!!
Why is there no option to choose Clean or Explicit for a podcast?
If you want submit the RSS Feed for your podcast to itunes, you can only do it with the itunes:explicit Tag.
This tag should be used to indicate whether or not your podcast contains explicit material. The three values for this tag are “yes”, “no”, and “clean”.
But Rapid Weaver has only YES or no Tag!!!
