Which Cookie notices solution is the best?
Can anybody recommend the easiest to use Cookie Notice solution for RW Classic? Thank you
Hi, here is Minicookie from Stacks4stacks. I do recommend it a lot. But you should ask William Woodgate (at Stacks4stacks) about his new product. Cheers
Hey @hucky,
I use CookieManager ($free, stacks4stacks.com). The learning curve is slightly less than steep, but once you get the hang of it, you can do everything regarding GDPR with this tool.
Here it is in action:
Erwin
I use biscuit box 3
