Just starting a new foundation project and thought I’d give Yuzool’s Nav stack a whirl.
Problem is, any content added to the pages simply sits on top of the Nav bar. If I add top margin to the content it pushes the Nav bar down as well.
Am I missing something obvious?
Ok - so found the ‘start content below navigation option’ but it doesn’t work directly. Still have to add lots of margin only now the margin does work.
Still seems odd to have to add top margin to stop overlap - is this normal?
Looks like you found the solution!
Yes that option enables that mode then you are free to add Margin/padding Reason being some people want the navigation to go “over” the content like here: http://demo.yuzoolthemes.com/navigation/page-2/page-3/
