Hello Everyone,
I wanted to let you know that I’ve just released the EditsPRO stack. EditsPRO will let you add editable areas to your Stacks 3 page that can be edited by up to 4 different users each with their own level of clearance and toolset.
EditsPRO builds on the idea behind the Kuler Edits stack and adds a lot of the most requested features from users.
#Features
Multi-user - EditsPRO allows you assign multiple users that can have varying levels of access to your editable areas
Single login - Just a single login button (icon) per page, regardless of how many editable areas there are
More Secure - EditsPRO will NEVER publish your password to the web. Instead, EditsPRO included a 'password hash" generator where you can create a more secure hash that will be used to check against your password when logging in. (This does require you to make publish your website to generate your hash(s) and return to RapidWeaver to continue building your site)
#Requirements
PHP 5.6 - Please check with your hosting provider if you are unsure about what version your website uses. If you are using php 5.5 or below, you can most likely update to version 5.6 relatively easily. (Again, you may need to ask you hosting provider for help)
Stacks 3 - EditsPRO will ONLY work with Stacks 3. That is ok though, because Stacks 3 is well worth the return on investment.
RapidWeaver 6 - You will need to make sure that RapidWeaver is up to date.
Demo Site
Videos on Vimeo
Product Page
EditsPRO will sell for $24.99 but if you use the code “smile” you get a 25% discount upon checkout.
Plus I have special pricing to anyone who has purchased the Kuler Edits stack … you get an additional 60% off (keep an eye out for a newsletter with more details).
It’s hard to believe but I have been RapidWeaving for nearly a dozen years now. I’ve released hundreds of themes and more than one hundred stacks during that time. I am so grateful to each of you who have supported my products through the years.
Thank you
Gary
