Since upgrading to 8.1.5, I have been receiving an error message when previewing Stacks pages. This error message is not the same as error messages I have seen documented created using the ThemeFlood Blank theme and GoCMS.
The error I received is as follows:
Fatal error : require_once(): Failed opening required ‘/private/var/folders/9p/c9h83wl08xj__r0059b3v95r0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/43280/document-0x7f8374f933a0/RWDocumentPagePreview/rw_common/plugins/stacks/cmsgo/lib/cmsgo.class.php’ (include_path=’.:’) in /private/var/folders/9p/c9h83wl08xj__r0059b3v95r0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/43280/document-0x7f8374f933a0/RWDocumentPagePreview/index.php on line 58
Usually when this occurs, I save my document, quit, and restart Rapidweaver. This clears the issue temporarily, but the error continually reoccurs. Is this a bug or am I doing something wrong?
This has been happening to my projects since 8.1 (ish). I have a stack of my own that has a php “require_once”. Every so often I get the above error where RW appears to be losing track of things. Simply closing and re-opening the project resolves it.
It happens so inconsistently and only every so often, in my case, I haven’t been overly concerned. But definitely a Version 8 feature and you are not doing something wrong.
I’m testing the demo version of Rapidweaver 8 and I get a similar message for every page on my imported site.
Fatal error : require_once(): Failed opening required ‘/private/var/folders/_f/l8dgpgtx607_r4g96937ts7r0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/14676/document-0x7fd045c18520/RWDocumentPagePreview/ads.php’ (include_path=’.:’) in /private/var/folders/_f/l8dgpgtx607_r4g96937ts7r0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/14676/document-0x7fd045c18520/RWDocumentPagePreview/reviews/fortran/fortran.php on line 42
I’ve updated all addons, tried resaving etc. but to no avail.
