@timmytoad, I would add that personally, if I were to visit that site and have to enter my password every page I wouldn’t be on that site for long regardless of saved overhead or not lol, so I suggest the template method for sure.
Yep i shall just have to give it a go, good idea. It wont happen yet though, the project i have in mind is still being created in my Grey Matter, i have to get ALL the content all together all in the same place first.
That WAS interesting though, about the mention of a PDF file not being protected by Page Safe, it sounds as if the Link to the PDF file was outside the HTML page that Page Safe was on !.
Cool @timmytoad, try to remember you can use a set of characters (passphrase) or 4 digits or 6 digits
Also, does not allow for more then one passcode… you would need something else for additional users/passcode management. And, before you ask, my only recommendation would be a database solution not a CMS solution.
I have used Page Safe on dozens of sites and it is ridiculously flexible.
I have some sites with only one protected page and other with 50+ protected pages.
On some of the sites I have 3 different Page Safe configurations for 3 different users. Multi user page safe + Stack Safe allows for some pretty complex and dynamic web applications.
My recommendation and standard of practice is to use Partials for this. There is no reason why you would use a template stack instead of the partials feature. The template version is only still accessible because it prevents users from being required to convert all of the previously used templates into partials.
Also, Page Safe only requires you to enter the password once across all pages. It even has an option to set how much time you would like to allow before requiring the password to be entered again.
Hi @BrandonCorlett thanks for giving me your pennyworth in answer to my question, it reminds of summat that my old Dad used to say, there is always more than one way of doing anything !!.
Thanks to both @BrandonCorlett and @Turtle I am continually finding out what i can do with RW, many thanks to both of you.
@BrandonCorlett@Turtle Hi All, i cannot admit to listening to ALL the podcasts, not yet anyway, so i must have missed the explanation of the “Beaver & Bison” show, can someone please explain ? otherwise, in which podcast episode was the explanation divulged, thanks.
Hi all, I cannot seem to make the page safe stack works on my home page. It is placed on the top of my home page but it doesn’t show on the page after publishing. What could be the reason.
