RW Classic 9.2.1: I am using a theme whose developer has retired. (Uprising) The general settings banner container is disabled. There are 5 banners to choose from in the Theme’s settings page; 3 of them are images that I installed myself but I have forgotten how I did it. I dragged an image into the folder in the Library that contains the other images, but the new one doesn’t show up as a choice. Can someone tell me how to install the new image?
What theme are you using?
Uprising.
Hi @wconable,
What happens if you rename your desired image and give it the name of one of the images that come with the theme? You’ll need to rename the targeted default image first though, as macOS won’t allow you to have two files with the same name in one folder.
Erwin
The problem was finding the correct place to place the images. I finally did find that and then all was well.
