What is the image on the left side called? How can I put an image there?
Hi Saran
That do believe that would be the site logo, you can change it to your own in the site settings.
Brad
Okay, thank you! But I wonder what size of logo should it be.
The image used in his example is 4kb, png format, 200px x 200px
As I do not have the Theme, I don’t know if this is something that can be adjusted inside the Theme settings in Info Panel or not.
PNG for transparent background
Brad
Hello Brad
This theme is included with RW6
@iSeeThis
You can use any sizes, Affero scaled automatically. Try with different sizes.
I have tried with 2400 x 1800 px and smaller. Bigger is more interesting!
When you shrink the width of the page, the logo slips above the title and slogan.
DOH!!! Can tell where my head was huh! lol
Thanks for pointing that out @Oscar, You’re the best as usual
Brad
Thank you all you guys!
