Anchors and links on the same page
I am able to add inline links with no problem and to add links to other pages. Links on the same page, not so much!.
The site is www.taxicabmanager.com
I am trying to add links to the icons on the top of the page, so that they navigate to the anchors set in each section on the same page.
I have inserted the #rosters link into the link URL of the button as #rosters. I also tried www.taxicabmanager.com/#rosters, also http://taxicabmanager.com/public_html/index.html/page0/index.html/#rosters, also http://taxicabmanager.com/public_html/index.html/index.html/#rosters
What I can’t seem to work out is how to add the anchor to the roster section. I added an html stack in the rosters section with the code: “a name=“rosters””/a" - does not do anything. (can’t display the anchor code with the a name as it is typed) Is an HTML stack the way to do it?
Anchor posts seem always to be about linking to another page. I feel this should be dead-simple, but I’m stuck.
Cheers - have a great day!
(I also note that the RW Link icon always appears dim - not sure why it is so, so I can’t seem to use it to set links.)
Ok all sorted. I downloaded the Links & Anchor stack from Joe Workman and it does exactly what I want.
Glad you got it sorted…
As for image, you would assign a link to the image (in edit mode) of url: #myanchor, this will look for a anchor somewhere on the page named myanchor.
When you want to place the anchor, you want to use:
<a name="myanchor"></a>
where the link will go to when clicked from above.
Make sense?
Brad
Thanks very much for the reply Brad.
I’m still confused as to where to put the anchor though - no issues with the link.
So the anchor area I want to go to is a Foundation 2 column stack that has an image, a header, and a paragraph. Where would I put the Do I add an html stack inside somewhere?
Cheers - and thanks again
Steve
If you’re using JW’s Link & Anchor stacks, you just put an anchor stack immediately above the 2 column stack. That way it will work on mobile properly also.
Brad
I’ve got that working.
For my own edification - where would I put the anchor with the stack setup above?
They are 2 different stacks
Link Creates the link to anchor item: <a href="#anchorlink"></a>
Anchor creates the Anchor item: <a name="anchorlink"></a>
Not sure of your question, you have a 2 column stack, put the anchor stack immediately above the 2 column stack as I said prior (immediately above the content you want linked to).
Your website is working as advertised… what is the issue you perceive?
Brad
All good Brad - I was just trying to figure where I would place the anchor if I wasn’t using the JW Link stack.
But that’s what I’m using RW for - so I don’t have to worry about putting code in!
Cheers
Ah
Well, you could use an HTML stack for sure for the anchor html code in the same place, immediately above the 2 column stack, but the link can be done right through the image stack (if a plain image stack)…
Brad
Well that’s what I thought - and I did try it with an HTML stack - but must have had my syntax wrong.
Anyway - thanks
