Firstly I am using latest RW, Aspen theme and stacks.
I have a specialist photography page. This single page has sections on Aerial, panoramic etc. What I would like to do is to create a link at the top of the page that took a visitor directly down the page to the start of the relevant section, I tried using resources but that didn’t work.
Is this doable as standard, or is there a stack which would create a 4th link option other than the standard URL, page, resource options.
There are two sets to the process. First, you need to create an “anchor”. This is the target of your in-page link. You then use a text link or a button stack to link to the anchor you want it to go to.
There are a number of stack that do this.
Here’s a basic, free one:
Here’s another that adds smooth page scrolling to the section:
