Is there a stack to animate a word, one letter at a time? I’m trying to emulate a very old Flash script.
Here are two donation ware possibilities:
Although I used to enjoy these, I now think they’re a bit of a distraction. Also, I found that Header Pro animations mucked around with the centring a bit – great stack though! What I think works better is an animated background (possibly an animated SVG) with static text on top. Just a personal preference.
Potion Pack’s Type It stack does the trick if you are using Foundry
https://foundry.elixirgraphics.com/documentation/type-it/
Foundation here. Thanks for replying though.
I’m guessing that Header Pro already does the trick but BWD also has the Typer stack: https://bigwhiteduck.com/stacks/typer/
hmm. nothing quite fits. I may have to create an animated image and import that.
