Armadillo 2.9.5 — Image Resize & Placement Gone?
Installed 2.9.7 on two sites. Working great. Thank you again!
You bet~ :slight_smile:
Thank you @nimblehost for the updates, but I am noticing a problem with alignment of text and photos in table cells. The photos and text above the photos towards the bottom of the “Open Letter” at https://www.bridgemd.org/ will not center align, though they align as expected when viewed in the solo content editor. This behavior is the same in Brave, Firefox and Safari.
According to the source code on the site you specified, no text centering formatting is being applied to the text elements in the table cells, which explains why it does not appear centered on the live page (irregardless of what the content editor displays - perhaps it’s older styling created in earlier versions?). When I attempt to center text in a table on my test site using Armadillo, I’m unable to do so, which leads me to believe it’s not functionality which is supported by the content editor.
If you wish, you can always apply custom CSS to table elements (or any elements) to tweak styling not possible in the content editor (or to override theme styles, fix other layout issues, etc). In this particular case, something like the following should work:
.armadilloContent table tr td { text-align: center; }
Custom CSS like the above can be added to the Custom Styles field in the Settings tab of Armadillo’s online dashboard.
That works. Thanks Jonathan!
