Armadillo Blog help
I have a support request into @nimblehost, but haven’t had any luck yet, so I thought I might try you guys.
I’ve set up a solo content section on my site www.free-books.org.uk which works fine.
I’ve also set up a blog page, which doesn’t. For some reason, I can’t get the post and page content IDs to be the same and so the content is obviously not showing.
Is there a way to manually change IDs or does anyone have any other suggestions?
Many thanks in advance.
Did you try to change in Rapidweaver the content ID of the blog stack in order to match with the blog page ID in Armadillo (tab “pages”) ?
Hi Anne,
I have been trying that (I promise I tried it several times yesterday). However, on trying it again, it seems to have worked.
You clearly have some kind of magic influence (as well as my gratitude for your time).
Regards
Barrie
