Have been using RW7 for some time am looking to get solid edge to edge colour in selected content areas of the body content not the whole background has me stumped at the moment Any ideas or setting of stacks etc to achieve this the.
The Voyger pro should do this but I am stumped.
Don’t have Voyager Pro, so not sure, but the theme needs to have an Edge to Edge area. It looks like some of the ExtraContent areas have that option, so I would look into using one of those.
Hi Robert
It has been a long time since I hand coded html can you do a a override in the code setting panel the body section to override the with setting of the body? or in the CSS section?
Hi Robert I worked it out through extra content will do as a workaround for the moment.
Cheers
Hi there @cookie!
Voyager Pro doesn’t have an option to achieve what you’re looking to do. You’d definitely need to write your own custom CSS to achieve something like that.
