Beta 25 - Issues
@dan
Two issues I have found so far –
1 - The double click in blank part of text component has returned. You have to double click on text in the component to enter editing mode. This was fixed in Beta 24 but has now returned
2 - I am also seeing the editing window turning gray. I can save, close the project and re-open the project to return to work. It has done this 3 times while working. This was the first time I have seen this.
Same as reported here: Give me a clue what happened
Just wanted to let you know.
The fix caused a problem with button icons appearing in the wrong place. More investigation required to fix the initial problem.
We’ve seen other reports of this, we started looking into it but have had no luck reproducing the issue. Have you got any ideas on what triggers it?
Perhaps you could share your project and a rough idea of what you were doing at the time the editor went grey?
Fingers crossed, we’ll get all this fixed up in the next few betas!
All three times it happened when I double clicked on a text component to edit. All three were different text components. All three times it occurred when I double-clicked kind of fast.
elementsapp://downloadDocument/A6gJQyE6PpNC
Infantry Regiment Parachute Wing Backgrounds page was what I was working on when it happened
