Hello again…
Feels like we’re firing on all cylinders at the moment. Here’s the third beta in as many hours. Enjoy!
What’s new in Beta 27?
- Fixed an issue when dragging root level pages
- Improved stability in the editor
Get the Update
Please note: Sometimes it takes a while for the update to propagate. If you don’t see the update in-app, you can download the latest build of Elements from the confirmation email you received, as that link will ALWAYS give you the latest version.
Give Feedback
Can I join the Beta?
We’re not taking on any more beta testers at this time; however, you should sign up here to be notified as more places become available.
