Blog plugin issues (SOLVED)
I am trying to use the built in Blog page type (previously used RapidBlog/Blogger combo, but has become a bit unreliable), but I have run into a couple of issues.
Firstly, I don’t seem to be able to add a category to my test post, the area is greyed out and inactive in RW. I am using the latest 7.1 Beta and the Copper 2.0 theme from Will Woodgate (Seydesign originally).
Secondly, when I click the link in the post summary to “read more”, all formatting is lost. You can see the blog page here.
Thanks in advance for any assistance!
Mark
Thanks @dan, looks like the latest Beta (18297b) has fixed the issue!
Regards
Mark
Actually @dan , spoke too soon. The latest Beta has fixed the missing formatting on the full blog post page, but I am still unable to add categories to posts in the edit window.
See attached screenshot. I am unable to double click the selected blog, or add any categories into the categories box on the right hand side.
Check to be sure you’ve enabled the Categories:
Doh… I am an idiot, many thanks for setting me straight!
Nah, it is just one of those things that happens. Easy to forget about it since you only set it once and then forget about it.
