worxeasy
(JulianLandthaler)
17 December 2019 11:28
1
Hello! I bought the Go CMS Unlimited stacks and licensed them already. But every time I want to preview the page in my browser, I only see a blue screen. With the shortcut to admin the page I can see the editing page then, but as a normal visitor of the page, you can’t see anything except the blue screen.
Does anybody know anything about this problem?
teefers
(Doug Bennett)
17 December 2019 12:07
2
Double-check you configured the license key correctly.
If that doesn’t solve the problem you need to contact @yabdab support or at least a URL to the page.
yabdab
(yabdab)
17 December 2019 13:12
3
Looks like you are using the Page Lock stack?
If so, then you need to login ( Control-shift-x ) to get passed the “Lock” screen.
When you or a client need a page available online to edit, but also hidden from public viewing, you can use Go Lock. Lock will obscure the online page, and require password validation for viewing a...
worxeasy
(JulianLandthaler)
17 December 2019 13:41
4
I’m using the Go Lock stack, which was in the Go CMS bundle.
teefers
(Doug Bennett)
17 December 2019 13:50
5
And does the control > shift > x key combination not bring up the login screen?
worxeasy
(JulianLandthaler)
17 December 2019 14:03
7
The problem is solved, thank you very much for your fast responses!
system
(system)
Closed
17 January 2020 00:03
8
