Blueball Freestack navmenu dropdown submenu arrow not showing up
My site is here: http://www.stormdesignprint.com/fowler/
I have the answer to this somewhere but I just can’t find it! I need to find the code that will correct the navmenu dropdown subpage arrow icon and make it show up correctly, it should be showing as an arrow but it’s a square and it’s something to do with fonts, but I just don’t know where I saved the fix for it…(sigh)…anyone?
Gabrielle
Found it! Just in case anyone else needs to know, you add this to your header code area:
Then it works like a charm.
