Weaver Themes Drop Down Menu Icon
I have a very old site for a client built using Weaver Themes “Avante” theme…
http://www.photofoil.com
and I have just opened it up to make a few alterations and I have noticed the Little Down Arrow icon next to the menu items with a sub menu is now missing and is showing up with a question mark.
Can anyone advise me on how I can fix this problem?
There are a few errors with some resources missing. One of them is Font Awesome so I suspect that’s the issue.
Maybe a complete republish would help, but as it’s an old them, there could be other issues.
Also, all sites should now have an SSL certificate installed.
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (stacks.css, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (jquery-2.2.4.min.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (font-awesome.min.css, line 0)
[Error] TypeError: undefined is not an object (evaluating 'e.attrHooks.value')
	(anonymous function) (stacks_page_page2.js:2:822)
	Global Code (stacks_page_page2.js:2:7071)
If you’ve not looked at it for a while you could check to see if there’s a newer version of the theme that fixes this.
Another thing to try is Marathia’s free FA4all stack. That may fix the problem.
Rob
Thank you Neil and Rob,
I figured it out!
I opened up my previously saved copy of this RapidWeaver file and I noticed the drop down arrows were working fine. So that led me to retrace my steps of the alterations I made in my recent update and it turns out that the culprit was ticking the box for “Generate Cache-Busting Links” in the Advanced panel on the RapidWeaver site General Settings. Unticking that box restored the drop down arrows and it’s all up and running again.
