Good to hear that it has been reported. I never use the offsite page.
I’m also experiencing an issue with a project using Offsite Pages. I can open the RapidWeaver file but if I try to save it I just get a spinning beachball and I end up having to force quit.
How can we fix this?
I just tested it and if you DON’T put the url in the settings for the Offsite page, it does indeed crash. When the complete url was entered, no crash for me. I’ve noted it anyway (since that shouldn’t happen either way) and I’m sure we’ll get that sorted soon.
I can confirm this works when you have a URL entered but does not if no URL is entered.
Update:
This gave me endless problems. Here is what has worked reliably (7.2.2) - Thanks to @jabostick for the help
Offsite page: Ensure folder has name - perhaps ‘OS_1’, ‘OS_2’ etc if multiples are being used as Virtual Menus / Sym Menus (as per Joe Workman’s Font Awesome Weavercast)
‘#’ in the web address.
Sorted.
FYI
Have tested this in the beta for 7.3 and have had no problems.
Same problem… RW does not publish offsite folder so it doesn’t work.
How could i do to work it?
Any suggests please?
I need to have an offsite page …
Could you help me please.
This is my url: http://www.mobila.it/
RW does publish offsite folders. I’ve done at least 2 new sites this week with offsite pages and zero problems.
Maybe the issue is elsewhere.
The offsite page not work if you try to click it …“AREA RISERVATA” into this url:http://www.mobila.it/
Any suggests to fix it please?
Here the screenshots … maybe i’m wrong something?
Thank you
RW does not publish OFFSITE folder into my HD’s Folder Site… so i can’t publish it to my server… why?!
I have RW 7.3
and RW does not publish OFFSITE folder into my HD’s Folder Site… so i can’t publish it to my server… why?!
Do you have the option use redirect page checked?
No as you can see into my two screenshots above… there is an href empty because the offsite folder isn’t published to the server and to my local website folder… how can i do to publish an offsite page?
If you go to http://www.mobila.it/offsite/, the correct page seems to open, which suggests the offsite page has been uploaded to your server.
No it doesn’t open yet… if you go into the home page http://www.mobila.it/ and then click to AREA RISERVATA the last page into Nav Menù it doesn’t work … i dont understand where did you find that link.
I can’t upload and publish the offsite folder…
OMG
Have you tried marking the offsite page as “changed” and republishing?
Because the “offsite” page is the “offsite” folder on your server, it can accessed by anyone.
Yes i know but why if i go to the Home Page and then click to AREA RISERVATA the last page into Nav Menù it doesn’t work???
