We have been trading for many years without any security issues (using Rapidweaver along with an ECWID payment set up).
Recently, scans by Security Metrics are showing jQuery errors which means we are now technically not compliant and they have asked us to correct the problem.
I thought it was due to old stacks software, but I think we are running the most up to date version. I asked ECWID if they could shed any light on this and got this answer:
Ecwid does not use jQuery.
Additionally, I have checked your website https://www.medlarpress.com/ and see that it was built using RapidWeaver. I checked the scripts on the website and found that the jQuery script with version 2.2.4 comes from RapidWeaver itself.
You may see that it belongs to RapidWeaver because the URL for the script includes rw_common. In this case, I recommend reaching out to the RapidWeaver support team to inquire about the jQuery script and how to update it.
So there you have it - I’m already operating on the edge of my own ability . . . can anyone show me a simple way to remedy this?
I’m currently also half-way through a conversion to elements, so hope the problem won’t appear there as well!
