The clear menu stack seems to be the answer for me.
Unfortunately there seems to be a small snag and any advice how to overcome it would be most appreciated.
The menu works fine first time, but when wanting to return to the main menu from a drop down it won’t until the screen is refreshed.
Any ideas?
You can see it at www.cheltenhamcroquet.org
Dan
Hi Dan,
I see what you mean. Do you have the option to turn off hover and only activate on click just to see if it makes a difference?
So close to home too. I’m 15 miles down the road in Cirencester.
regards
Nick.W
Nick,
Thank you for your prompt response and sympathy.
I’ve carefully looked through all the setting and not been able to find an option to click rather than hover.
Small world isn’t it.
Thanks again
Dan
Interestingly, when the menu is toggled the links work from child back to parent.
It get curiouser
Dan
Even worse. It disables all the other links on the site!
Got to take it down and rebuild the conventional menu.
Disappointed
Jonathan solved it with a bit of code
Thank you Jonathan
Perhaps we flag the developer @1LD for help.
Thank you Jonathan
