Howdy- This one should be easy, but haven’t found the trick:
How do I make it so If a user clicks on a button or link, a PDF is downloaded instead of displayed in a window? All my links display the PDF in the browser window.
I’ve always used the Zip approach. Simple. Place on your server with FTP app, or using @instacks Repository stack. I’ve never had any problems with students downloading on computers (both Win and Mac). I have no idea about iOs.
The nice thing about FTP is you can zip one file or a folder of files. Same approach works in either case.
There are more sophisticated things you can do, but this approach is simple, fast, and effective.
My Bad! I totally forgot to reference that I searched and found the solutions such as DooBox, zip, and javascript/html5.
My DOUBLE bad! I previously looked at an old link to TrueDownload and saw it was no longer supported. BUT this thread inspired me to go directly to DooBox;s home and double check… Whadyaknow!.. there’s a TrueDownload 2. I’ll that a go.
Also, I tried the javascript and the update html5 but wasn’t able to get it to work within RW’s link dialog box (probably user error). Finally, wish I could link to Zip files but my customers are execs inside Fortune 500 companies and these days zips are pretty much blocked for security purposes. Bummer.
