Hi there,
is there a wa to convert/copy blog posts from a CMS to another? Armadillo to Pulse and/or TotalCMS and viceversa?
Antonio
Hi there,
Antonio
It depends on the type of blog you have. For Total CMS Joe has a Tumblr Blog converter. You can also just copy and paste the content into Total CMS (sure that is the same for other blogs as well).
Hey @tangerine62 - think as @zeebe says copy&paste all the things will work.
For larger sites that could be a pain so Pulse also has an RSS importer (you could use that with any of those) and if you are coming in from WordPress we also have an importer from WP too:
The WordPress importer:
https://teleport.pulsecms.com/step1.html
Hope this helps!
Thanks to @zeebe but @yuzool it isnβt clear to me how to use the RSS importer.
Can you please clarify?
Try the demo (login > Blog > Import):
https://demo.pulsecms.com/admin/index.php?p=blog_import_from_rss
This imports from RSS and you can set the pagination variable (if there is one) and how many pages to search and it will get you most of the way. Try it out
