Comments - not Discus
On my blog I was using Discus to allow followers to comment but to do so they had to register and/or login. It worked well as comments were applicable to the blog entry.
To overcome the problem of logging in I look for an alternative and I found a Stacks4Stacks addon called “CommentS” it was exactly what I wanted, a beautiful and easy interface with a basic numerical anti-spam question… or so I thought. the problem came when after implementing it someone made a comment and now that comment appears on every blog page, not just the entry he was commenting on.
So my question is quite simple, is there another commenting addon I can get that will have a database that will separate the replies by post?
This has been fixed with help from the developer. There is a setting that allows for a common database or a different database based upon the page name. I needed to use the latter.
