I have had some issues on this site trying to get the Universal Code to work properly in my RapidWeaver project. I decided to go into the index.html file on the server and edit (add) the Universal Code right before the /body tag.
It’s working properly when I edited the code through Transmit. So, I went back to RW and added the UC to the code section of the page, republished and checked it again. No luck. So, I downloaded the index file, deleted the code in RW and republished so I could add the code via Transmit and then download the index file to compare.
There is a strange bit of code that is adding to the RW file: ?rwcache=562785330
The top image is the downloaded version via Transmit. That code was not present before or after I copied/pasted the UC from Constant Contact.The code is coming from line 639 and somehow duplicating itself within the script that I paste.
Any help would be appreciated as at this point EVERY time I now update their website, I will need to edit via Transmit. I’m dreading the thought… ![]()
Using RW7.5.6
