I am having great difficulty in successfully creating slideshow banners in RW7. I have Superflex 3 and many other options, but nothing seems to work. Any help or suggestions? Thanks!
I am using Superflex 3 it works fine you can see it on a site I did. http://www.towerbungalow.co.uk
There is a huge amount of flexibility to it so you may want to read through the manuals at nickcatesdesign.com
Hi Scott. I can get Superflex to do what you have done on your website. I want the slideshow to appear in the area where the flowers are on your website. Any ideas?
what theme are using as well as stacks version are you using as well
do you have al link
