I cannot create any more partials. If I select multiple stacks and click on Partials, nothing happens.
But i can drag and drop a partial from an existing to another project.
It also doesn’t work anymore for older projects where I have already created partials.
Interesting - I have exactly the same problem today! Although I created some partials no more than a few days back, I can’t today. Very odd. I shall experiment and report back.
Same here, can’t create a partial from multiple stacks only from one stack, so I have to group them.
(As I group my stacks most of the, I didn’t realise that there’s an issue )
You can select a single stack, make it a partial then add additional stacks to the partial.
But I never believe you could select multiple stacks and make a partial.
I haven’t used this for some time but I’m almost sure that this is how it worked. But maybe I am wrong. In any case, this approach would be logical for me.
If I select a stack and make a partial out of it, then I can’t pull another, already existing stack into it. I have to create the different stacks within the partial. To create a partial out of several stacks afterwards, this does not work, if I am right.
I’ve had this issue before. It took me a bit to figure out how to get around it.
You can select a single stack and make a partial from it.
You can select multiple stacks and make a partial from them.
What hasn’t seemed to work for me, and I’d call it a bug as the button for partial is active but clicking it doesn’t do anything, is select a stack and a partial and make a partial from it.
For now, the only thing that seems to work is making a partial from a single stack and pasting the partial into the new partial you just created.
Or maybe I’m partially wrong as I just tried two stacks and that still had the same weird behavior.
I did have a similar problem after an update. I tried the reboot it didn’t work so I booted using Command+R and did a Time machine backup to the date I knew it worked. Make sure you backup all your essential files to another hard drive as you will lose all the data going back to the selected date.
I am not a computer wizzes but this is probably a conflict with another application.
