Hi
I have made a test page in RCP using the RCP grid stacks.
What I want to do is add the button ADD TO BASKET under the description text. That way it is visible without scrolling to below the product image. Here is sample
Does anyone know how I can so this?
Just move the Cart stack under the description as you would do with any other stacks.
If you completely remove the Cart stack, customer is automatically redirected to Cart page without having to click on the button.
I think in this case I can’t
Because I am using the grid stack to import entire categories directly from the Rcp page
That way I am not actually using the cart stack as the add to cart button is directly imported. So I think I would have to use css not sure
